Hi I have a network as diagrammed below. Ideally I would like to use network isolation with blocking inter-VLAN routing using VLANs to separate the wired clients (the laundry card machine and surveillance computer) and the Asus Router from the Ubiquiti U6-Mesh's. That way people on the Uibquiti Wifi cannot communicate with the wired clients or Asus router for security purposes. Everything looks pretty straightforward with the Unifi OS i.e. apply VLAN to wifi instance and then setting the network isolation traffic rule. Is this a good way of setting things up or is there another/better way of doing things?
Also if this is a good approach, which non-ubiquiti switches do I need to replace to support Unifi VLANs and which Ubiquiti switches should I use? I heard the Flex Mini cannot support STP and therefore might not be a good choice. The Flex, Lite 8 PoE, and 8 PoE Gen 1 look like good candidates if the Flex Mini is not appropriate. And it looks like I might not need to replace switches 1 and 4 since all traffic on these guys is in the same VLAN.
Thanks for the help!
