I have a amd fx8350 cpu and I'm planning on overclocking it. I'm worried on doing that with the stock fan, not to mention how loud it is.
I wanted to get a really quiet water cooling system that'd fit into my cooler master haf xb case, I'm already using the top 200mm fan mount.
I wouldn't want to spend over $60, $100 would be my max.
