Which way should the fan face in my case?
CardboardComputer
35
Hi everyone. I'm new to building PCs and just ordered parts for my first build. I haven't been able to find a clear answer for this anywhere, so I thought I would ask here. Which way should my case fan face; Logo and bracket facing inwards or outwards? I will be using two fans, one in front, and one in back. I do not want to purchase a dust filter. Thanks!
Dust filters are never required persay.
Would one be good to have? Maybe. Should you buy one? No.
Whenever the system gets dusty just blow it out with compressed air.
The fan in front should have the sticker and motor on the inside of the case, the exhaust (rear) should have the sticker and motor up against the side of the case.
(If you look somewhere on the outside of the fan there are two arrows, one showing rotation, and the other showing airflow direction.
Will this require a dust filter?
