Which WiFi card or Ethernet cable should I take for my system?
ars.arch01
56
Hi everyone!
I am building a PC now, and I would like to know which WiFi PCI-e card or Ethernet cable shall I take...
My system is...
http://
My WiFi router stand in the same room, and it is...
Technicolor
(EURO) DOCSIS 3.0 Wireless N VOICE CABLE GATEWAY TC7200
without any antennas.
Speedtest on my Laptop shows that the speed is..
download 34 Mbps
upload 2.4 Mbps
Is that possible to set a cable out of the router and connect it to Motherboard?
Or shall i go to Wifi card (which? i am ready to spend 30-50 euros on that)
Please give me an advice on that.
Thanks!
for a desktop, a wired connection is usually faster and makes more sense. Also an ethernet port is built into every motherboard.
How to choose an Ethernet cable that fits to my router? Are there any best ones ? Or they are simply all the same quality and speed?
Thanks !
