Which wire should be cut in order to cut off LED from my CM 200mm fan
siddharthkratos
18
On my Case Cooler Master Enforcer there is a front 200mm fan and i want to remove that red LED light from it(cut off)
I found the cooler on my case on google and it looks like this
http://www.pchub.com/uph/laptop/676-116377-27190/Cooler-Master-A20030-10CB-4MN-F1-Server-Round-Fan.html#
There are 3 wires going to the mid like heatsink so i don't know which is LED one
Left wire=Black
Mid wire=Red
Right wire=White
Any way to know which is LED one so that i can cut off red LED from my fan
Unless I miss my guess
Left wire=Black = Ground
Mid wire=Red = Negative
Right wire=White = Positive
Meaning the answer is none. Replace the fan with a non-LED version.
-Wolf sends
The link you gave is dead. the most logic explanation would be the white cable. the white cable on electrical circuit, normally represents a neutral cable. But because there is only 3 cables I strongyl think that the Led and fan are parallel mounted meaning that if you cut the Led power, you will cut the fan power to.
Link updated
So there is no way to remove/cut off LED ?
Noctua fans are excelent I strongly recommend it if you can afford it. Another cheaper solution is the Cougar I bought 3 yesterday on the specs they are exactly the same II would take the one cheaper for you. In my case the Cougar.
https://pcpartpicker.com/part/noctua-case-fan-nfp14flx
or the PWN Version :) good luck https://pcpartpicker.com/part/noctua-case-fan-nfa15pwm
and the cougar https://pcpartpicker.com/part/cougar-case-fan-cfv14hp
