White and Green PLED Power switch connection.
somethinggoeshere
9
Good afternoon and thanks for taking the time to read this thread. Well, for starters, I am currently building a computer. The components relevant to my question are:
Motherboard: MSI FM2-A55M-E33 FM2 AMD A55
Case: Rosewill ATX Mid Tower Black Gaming Computer Case Galaxy-01.
My problem is that this computer case came with this Pled power switch:
wi40cq059
I just don't know where to connect that cable so I was wondering if anyone could help me with this.
Thanks for the help!
Unfortunately, it does not have any labels though indeed that is where I have plug the other connectors such as reset sw and hdd led. However, this connector and the cable are far two different for them to connect in any way way. As a matter of fact: http://postimg.org/image/50slilyrh/
Also my mistake but that is the cable for the Power led, not the power switch. If anything, that cable seems more suited for a fan to psu connector
That's a Molex connector. You hook that directly to your Power Supply. I would bet it is connected to case fans that came pre-installed from the factory.....
Don't worry, the molex connectors are "keyed" so, you can't do it wrong & no harm will come of it...
Would you mind telling me how to plug that molex connector? Since the cable is a male molex connector, I assume that I need to get a female molex adapter?
Oh Thanks, so I have to plug into the PSU. However, would you mind telling me how to plug the molex connector into the PSU? Would I need a female adapter?
Oh, I'm sorry! I didn't see the molex connector. Your PSU should have come with some molex connections.
a molex cable is the same kind of plug that u pluged into your cd drive and mabe some other devices. its them 4 pin flat female connectors coming from the power supply. should plug in only one way.
