I'm looking for a white case to fit a Prime X570-pro and white ram and gpu and I've been struggling to find one
This is what I need:
-side (tempered) glass panel
-360mm aio support (ml360r)
-if the aio is gonna be in the front (and I'd prefer it to be on front) then I want to be able to see the rgb fans so I would need a front panel
-but i'm fine with the rad on top aswell tho and in that case there is no need for front panel
-budget around $100 or less (anyways not over $110 maybe $120 if the case offers good value)
The closest to my needs I have found so far is the Matrexx 55 Add-rgb at around $50 with side and front panel but I'm not so sure about it since I've read that the cable management on that case is not so good and the build quality is bad and also I'd have to buy 3 more rgb fans (would 't be a problem tho, I could get them for $10 each)
