Question White DRAM LED intermittently appears on first boot, boots fine when powering down and booting again ?
abyss010
23
I've been having this issue where every few days or so, the EZ Debug DRAM LED is shining white and there's no video output, but if I power down and then attempt to boot again, everything boots just fine and there doesn't seem to be any issues when using the computer.
I went through google but I couldn't find anything relating to my exact issue, just people having no boot at all. Hoping this is just an oversight somewhere, but any advice would be appreciated as I'm totally clueless as to how to approach this issue.
PC Specs
MSI MPG Z490 GAMING EDGE WIFI ATX LGA1200 Motherboard
Intel Core i7-10700
GeForce RTX 4060
Corsair Vengeance LPX 16 GB (2 x 8 GB) DDR4-3600 CL18 Memory
Gigabyte P750GM 750 W 80+ Gold Certified Fully Modular ATX Power Supply
What BIOS version are you on for your motherboard?
Does the issue crop up when you're working with another kit of ram? How are you cooling the processor in your build? Temps when you experience the issue?
BIOS version: E7C79IMS.1D0
BIOS build date: 08/27/2023
I'm reluctant to update the version as I have heard of issues with this particular motherboard.
I don't have another kit of RAM.
The cooling system is a Corsair H100x and 5 120mm case fans.
I don't know the temps because the PC doesn't boot to any display when this happens (as mentioned in my post) but I assume everything is the usual 30-40c.
