Question white flash when i turn my PSU on
KylerZ
33
I have b550 AORUS elite v2 and whisper 650w gold I usually plug the pc into the wall socket first then I turn on my PSU but I see a white flash for a second then the pc works normally is that normal ? i think it is the RGB of the motherboard I'm not sure
Is the flash something new?
If it came from inside the PSU I'd be worried.
Not sure what to make of it if it came from somewhere else, especially if not accompanied by a noise like electrical arcing or a pop sound. It could be white LED's on the motherboard flashing, or the RGB setup you have, but could also be something on the motherboard.
Reactions: CompuGuy71
KylerZ
33
it is not accompanied by electrical arcing is it normal to see a white flash from the motherboard led when i turn the psu on ?
