White noise with new Sound card
Adam Young
77
Hi all.
So i've just installed a new sound card in my pc.
It's a Creative sound blaster Audigy Fx.
All the latest drivers are on there. All the old ones of.
Disables onboard soundcard in MOBO BIOS. Tried changing between front and rear jacks. still no change. Tried with multiple headsets.
Never had the problem before, any suggestions?
Thanks in advance, Adam
PS : Win 7 pro 64bit
You've put your audio cables into the sound card, right? (only asking this since you mentioned trying front and rear).
Is there a lot of white noise at low volumes or just at higher volumes? You'll get some white noise at higher volumes anyway, it can't be prevented.
Hello... I don't feel the audigy to be better at this point in time... I just dumpster'd a few of them the other day...
But I mean to say you may have got a Bad Card, try another one... you should not hear noticable white noise change between on-board and Pci cards... when using the same headphones or cables.
What On-board model audio chip do you have now?
I may take it back then. was hopeing it would just be better
onboard is : Realtek® ALC892 8-Channel High Definition Audio CODEC
Mobo is : http://www.asus.com/Motherboards/P8Z68V_PROGEN3/overview/
