White power led indicator of gpu flashes
sickaid
55
Iam an owner of a Gigabyte gtx1060 6gb G1 for about 4 months now.I played many games on this and everything worked fine until i started playing Assasins Creed Unity.In some menus the white led starts flashing (the one above the 8 pin connector which indicates power stability) but during the game its turned off (which should be).I have it set to factory OC via Aorus graphics engine.Oh my psu is 600w.Any idea whats happening?Its the only game that does that.
If this light is flashing it means the power to the card isn't good. This could be due to either the PSU or the connections to the PSU.
I would reseat the connections (with the PC off and unplugged) and then I would look at the PSU voltages to make sure they are in spec.
