Alcohol is a very weak cleaner. It absorbs water from the air, which dilutes the alcohol and weakens its ability to clean. 91% alcohol also is diluted with 9% water.
This dramatically reduces its cleaning strength. Using weak, water-filled alcohol is a bad process that can lead to labor-intensive cleaning. Make sure you specify the purest, most water-free alcohol you can find.
Cleaning using a "dip-and-brush" process actually can make boards dirtier and more prone to premature failure.
Most people using alcohol develop problems with white residues, especially when cleaning lead-free materials. If these residues are streaky lines across the board, you are not rinsing thoroughly. Re-clean the board. If the residues are an even, smooth layer of white film across a large area this usually indicates you have the wrong solvent for that flux. You will need to upgrade to a stronger solvent and the problem will go away.
