So the games I play mostly are Terraria, TF2, CS, and some other source games. I used to be able to run all of these at 120 fps before, but now it crawls. Terraria usually can't get above 20, and TF2 hovers around 80, and I use a max frames graphics config.
My hardware is as follows: (on a laptop by the way)
Intel Core i7 4800MQ @ 2.70GHz generally runs around 60 degrees
24 GB DDR3 RAM, cant remember how it was configured, probably 2x8 + 2x4
NVIDIA GeForce GTX 765M usually 60+ on high load
stockish motherboard, not a name brand but the model number is W35xSTQ_370ST
I've only checked my drivers thru windows, not sure if I should check more thoroughly. The ventilation is clear, I clean it monthly.
Any other details you need I can definitely provide.
Also if you want to talk to me about it on steam add me here.
Thanks in advance
Thanks in advance
