why are my dxtory and fraps videos low quality?
crazy2011gamer
108
hi guys ive been trying to record gameplay with fraps and dxtory but they come out low quality. dxtory is low quality. and fraps is super choppy and freezes in the video, not when recording. here is an example with dxtory. on 720p?
https://www.youtube.com/watch?v=XEUaLUz8Pug&feature=youtu.be
https://www.youtube.com/watch?v=f0muKLx152Y
http://imgur.com/Vf12Ehb,J5KcM28,tnPqcGU
i have two hdds not a sdd. i play mc on C: and record to F:
when im playing bf4 i play on F: and record on F:
messed up installation
What are the write speeds of the hard-drives? Are they both 7200 rpm? Have you used DXtory to test the speed of the output folders you are recording to?
You probably won't be able to record BF4 on to the F: drive and play the game at the same time without considerable lag.
they're both 7200 and i dont lag at all when recording bf4 i can get like 60 fps when recording bf4. minecraft 200+fps recording
Ok, generally the rule of thumb is to record to an extra-drive that isn't the one running the game you are playing. It may not cause in game lag because your processor can handle all the data, but it can cause problems in the encoding of the video.
Have you tried searching YouTube for a video that explains the optimization of DXtory or Fraps? (I prefer DXtory out of the two)
in the imgur link u can see im runny dxtory with a codec. but still minecraft comes out bad when its playing on C: and recording to F:
And one more thing, your DXtory video looks pretty good! You may just need to optimize the software to tweak it. Sometimes recording the game in different resolutions can change the final product. What are you using to render the videos for YouTube?
What graphics card are you using?
i used sizer to get 720p resolution from the game not the sides of the window. and used lightworks because i heard its a good FREE editing software, and rendering at 30 fps at 720p
fx 6300 with r9 270x
it doesnt look like ultra hd though thats the problem.
Ok, if you were using an nVidia card, I would suggest using shadowplay, but in your case, DXtory will probably work the best, perhaps even mirillis action.
http://mirillis.com/en/
I believe there is a free trial out there for Sony Vegas, might be another thing to consider.
Recording in full-screen tends to produce the best results for me.
