Install the software to control the rgb.i recently purchased a dutzo c520 mesh rgb, but the fans are solid white.
its only for a few seconds when turning the pc they are "rgb color".
any idea on how to fix , if it can fixes?
And what is "the" softwareInstall the software to control the rgb.
https://www.dutzo.com/media/aralnko5/dutzo-c520-cable-setup-v1-0.pdf
Have you followed these directions?
Assuming the addressable RGB is connected to the motherboard, then you'll have to use your motherboard's software to change the colors, outside the RGB button on the top of the case.
