As stated, my case's 3 x NZXT Aer F 120mm fans are really loud.
I have each plugged into a different fan header on my MSI B450M Mortar, and MSI's Command Center shows their RPM is between 1200-1400rpm.
I cannot get them slower (tried the BIOS, Speedfan and Command Center) and their rated max speed is 1500rpm - they are therefore running at 75-90% power.
Funny thing is, Speedfan doesn't even recognize them or my CPU fan (although that one is acting normal), only the XFX R9 290X. And when I used DC mode in the BIOS, they either switch off or run at those rpm's again.
Does anyone have a solution for this (apart from buying new fans and then maybe being stuck with them at those rpm's as well - although the Corsair fans are looking appealing atm)?
