Question Why can’t I unlock Core Voltage, Power Limit, Temp Limit, and Fan Speed in MSI Afterburner?
Lancelotsan
37
I'm using a desktop PC running Windows 10.
My PC:
i7-3770
H61M-DS2
16gb ddr3
I tried with RTX3060, GTX660 and now is GT9500, and got the same result.
For some unknown reason, MSI Afterburner on my system doesn’t allow me to unlock any of the following settings: Core Voltage, Power Limit, Temp Limit, and Fan Speed. Even in the properties menu, I don’t see a Fan tab at all.
After spending a lot of time searching, I was finally able to unlock Core Voltage thanks to a guide I found on a website named Steemit. I have to work with Notepad and many file to make it work.
However, that’s the only thing I’ve managed to unlock. I still can’t access Power Limit, Temp Limit, or Fan Speed.
In addition to that, the OC Scanner option is hidden and I can’t use it either.
Can anyone explain what’s going on with my PC and what I should do to unlock all of these features?
Thank you very much.
Which afterburner version are you using?
BIOS up to date?
nvdia.com driver up to date and freshly installed (select Option install new and delete all setting in setup menu)
reinstall afterburner
I use the newest version. I have just download it. Maybe it is 4.6.5 or 4.6.6 version.
Driver for GT9500 is 342.01 version (Nvidia stopped support GT9000 series from long ago).
I actually uninstall and reinstall MSI Afterburner several times, just one month ago. And nothing changed.
But I don't know about BIOS. Can you explain it more to me?
Hav you checked the Settings button and made any changes from there?
Fan speed has always been unlocked but you have to change it in the settings menu ,
Voltage control has been locked out of Nvidia cards " I believe " since the 600 series and was one of the last that you could BIOS voltage mod. After that even bios mods were pretty locked down.
Reactions: Lancelotsan
Unlock voltage control.
Unlock voltage monitoring
Force constant voltage.
It is the only thing I changed in the Afterburner properties. (But it isn't work, as I said above. I finally have to follow a guide I found on a website named Steemit, just to unlock "core voltage").
But "Power Limit", "Temp Limit", "Fan Speed". I still don't find any way to unlock it.
In properties doesn't have even tab about Fan, too.
