So I just upgraded from a 5800K to a 7850K. I have a G1.Sniper A88X. I used BIOS version F2 with the 5800K and had to update that to use the Kaveri. HW monitor used to read cpu temps with the 5800k but now it doesn't even have a line showing CPU temps. BIOS readings show around 50C, Speccy also doesn't show readings, EasyTune6 shows 23-25C on idle. That can't be right, I'm using the AMD stock cooler(will buy NH-D14 soon) so temps should be higher.
I need to read temps so that when I get an aftermarket cooler I can test what the idle and load temps are for OC purposes.
Anyone know why?
EDIT: Oh and the readings on AMD Overdrive is whacked. Turning off the boost(lowers the clock) gives readings of steady 70C on all cores. Turning on the boost(increases the clock) makes it jump around 60-70.
Anyone know why?
