Question Why do some wifi devices keep losing connection if I do not set an IP reservation for them?
thosecars82
89
I have seen this happen with some Tuya/MOES/Smartlife WIFI smart devices I tried, but not with all of them. Why does this happen?
Thanks
You need to be more clear about what you mean by "disconnect".
Very technically the wifi can be connected and active with no IP addresses.
If the wifi disconnects though it doesn't matter what you have the DHCP lease time set to.
Generally DHCP lease time is used to prevent running out of IP addresses. For most home users they never have anywhere close to 253 end device connected. Since many wifi devices now use random mac addresses each time they connect you might see a bit more but still nowhere near ever running out.
I would change the lease time to at least 24hr maybe even a few days. BUT this has nothing at all to do with the wifi.
thosecars82
89
With "disconnect" I meant that some wifi smart devices (smart plugs, light bulbs) will start showing an offline state every two minutes or so.
By the way increasing the lease time to 24 hours made the devices work as expected for the time being, even though I took them out of the DHCP reservations list. I wonder now whether the problem will come back again once the 24-hour lease time is expired.
lantis3
393
72
18,770
You want to keep the IP addresses of devices as steady as possible if not a lot of people using the network, public hotspot for example.
Getting a DHCP IP address requires some negotiation time between dhcp server (your router) and client devices.
Even public hotspot won't set a lease time as low as 60 seconds, which definitely will result constant disconnects, however.
As suggested, for home user and devices that's not going to change most of the time, set a lease time over 24hr is very reasonable.
