I am trying to get rid of the partitions on one of my ssd's, so I went to delete whatever was on it. But that didn't work because it said that I had to be an admin to do it. So I went to disk management to try and delete the data but, I didn't know that it just makes it impossible to do anything with the drive that gets deleted. But when I was installing windows, I had two drives in, so windows is dependent on both but, I deleted one so now I can only use windows edge without getting a prompt that says I don't have the correct JavaScript for the task. So I try to just reset my PC but when I click on the reset button my screen freezes. What should I do?
I would start again
Only have the drive you want windows on in the PC when you install windows on it, so unplug PC and remove data cable from hdd.
Boot from installer
On screen after language choice, pick repair pc, not install
Pick troubleshoot
Pick advanced
Pick Command Prompt
Type
diskpart and press enter
Type
list disk and press enter
This will show the list of drives currently attached to PC, make note of the drive number of the drive you want to wipe
If Disk 1 is the drive you want to clear, type
select 1) and press enter. A message will confirm it is selected
Warning: Diskpart Erase/Clean will permanently erase/destroy all data on the selected drive. Please be certain that you are erasing the correct disk.
Once you sure its right disk, type
Clean and press enter
The Command Prompt window will display the message "DiskPart succeeded in cleaning the disk". Close out of the Command Prompt window by clicking the red X in the upper right hand corner.
close command prompt when operation is closed
restart installer and put win 10 on ssd, it won't have any partitions on it now.
once pc works fine with just ssd in it, it boots a few times without problems, unplug PC and put other hdd in
look in bios and make sure it only lists ssd in boot order
if you want to delete anything off other hdd, use diskpart method on that as well.
