D
Deleted member 2841972
Guest
In every single thread I saw on some bunch of forums, people are able to run their 7600k on really lower Voltages. Whenever I try the same voltages on my same model CPU, I can never get it work properly. Every time that I copy their values, I face with blue screens or similar issues. Is this also about silicone lottery or something different?
Fround this table: https://images.anandtech.com/doci/10969/7600K OC.png I could never run my CPU on those "Voltages & GHz".
I don't mention the other threads that I saw and copied their values. In short, I want to know if the problem is my, my components, silicone lottery or something else.
CPU: 7600k
Motherboard: MSI Z270 Gaming M3
Thank you.
CPU: 7600k
Thank you.
