Why does my ATI radeon 5670 powercolor 1 GB DDR3 needs a 6 pin PCI E?
fajardokier
89
Currently I've search all of the 5670 card and it has no required 6 pins. Did I buy the fake one? Or did the salesman cheated me or factory fault?
and another question is.. what does Extra power (6pins) do to the GPU is it important??
HELP! :(
alvine
Splendid
im not sure if the 5670 comes with an 6 pin pcie power or not but it basically means the card needs additional power. yes it is important because the card will not display anything on the monitor unless you give it the power it needs and is designed for
badtaylorx
827
33
hmmm....that is strange....i cant even find that on the powercolor website...
i have seen instances where engineering samples have made it too the open market.
or perhaps a mis-branded 57xx???
either way....only one way too find out
FIRE THAT BAD BITCH UP!!!
fajardokier
89
If my GPU requires 6 pins is it powerful?
randomkid
2,846
169
I doubt whether you got 5670. Can you show us the picture of the box it came in & the card itself showing the 6PIN PCIe?
randomkid
2,846
169
You got the 5670 alright. But I can not make out the PCIe connector in your picture but the cable you are connecting to it does not seem like PCIe.
It's really strange if it does have the PCIe connector. Powercolor website specify no PCIe power connector. But your box somewhat look different than what is in the website with yours saying something like 2GB (blurr ) under the labels 1GB & DVI/CRT/HDMI.
http://www.powercolor.com/us/products_features.asp?id=308#Specification
I guess it makes your 5670 a collector's item. :)
fajardokier
89
No my PSU doesn't have 6 pin thats why I made myself a 6 pin which is copper cables.. And in my box it said 1 GB DDR3 and below is the hdmi etc and below that is hyper memory up to 2.8 GB. And in my computer I've checked what card is it. It says ati 5600/5700 that only appears even in GPUZ. I have a question... What is collectors item do? Or something.
randomkid
2,846
169
A collector item is something out of the ordinary and rare.
If it is not too much trouble for you & for the interest of making doubly sure, can you unplug your 6PIN copper cable & take picture of the graphics cards on its own showing the whole card with a clear view of the 6PIN PCIe socket in it.
fajardokier
89
Okay sure! I'll show you everything. But I'll show you next 2 hours because I'm not home yet :)
fajardokier
89
Okay here is my whole GPU
http://imageshack.us/photo/my-images/341/img3786g.jpg/
Here is the 6 pin
http://imageshack.us/photo/my-images/209/img3790d.jpg/
Here is my 6 pin again
http://imageshack.us/photo/my-images/607/img3792fw.jpg/
Here is my back panel
http://imageshack.us/photo/my-images/840/img3788q.jpg/
Here is my Outputs
http://imageshack.us/photo/my-images/268/img3793up.jpg/
And my Whole GPU again
http://imageshack.us/photo/my-images/268/img3795vu.jpg/
By the way I'm going to remind you again.. if i'm going to check my gpu in "Right click>Screen resolution>advance settings and adapter it only shows ATI 5600/5700 and it's not like this ati 5670 series, even GPU Z.
And another thing If I put my GPU without the 6pin to molex it does not work but if I put it, it works normally :))
devilking
20
http://imageshack.us/photo/my-images/688/capturegpu.jpg/
here is the advanced setting in screen resolution of my 5670.
Your card may be one of the prototype ones that ati produced at first hand and gradually upgraded them and sold the old ones to card manufacturers that's why no specific card number in your card
fajardokier
89
So do you thinks that's true?? or maybe I just got the other cards?
randomkid
2,846
169
Thanks a lot. Your card is really interesting. Can you take a screenshot of your GPU-Z too. It should tell the number of shaders & other GPU specs that we could check against the 5670 specs.
fajardokier
89
HAHA thanks! but we still don't know if it is fake or something.
Here it is:
1st tab
http://imageshack.us/photo/my-images/806/34545373.jpg/
2nd tab
http://imageshack.us/photo/my-images/210/38262994.png/
If you can't see it well there is a zoom. point your mouse at the picture and there will be a little pop up then click the magnifying glass
fajardokier
89
Here it is:
1st tab:
2nd tab
devilking
20
your gpu is juniper which is used for 5770 not for 5670. codename for 5670 is red wood. 5770 has 6 pin power cable. So it is evident that your card is a downgraded 5770 prototype on which they experimented the beginning with ddr 3 memory
Similar threads
