Question Why does my headset sound terrible on the pc except when in a controller
Sep 10, 2019
Ok for refference...
PC:
https://www.bestbuy.com/site/dell-inspiron-gaming-desktop-amd-ryzen-5-series-8gb-memory-amd-radeon-rx-570-1tb-hard-drive-recon-blue-with-solid-panel/6251740.p?skuId=6251740
Headset:
https://www.amazon.com/gp/slredirect/picassoRedirect.html/ref=pa_sp_phone_search_atf_aps_sr_pg1_1?ie=UTF8&adId=A04678713BMYPI1Q65AZ7&url=/BENGOO-G9000-Controller-Cancelling-Headphones/dp/B01H6GUCCQ/ref=mp_s_a_1_1_sspa?keywords=kotion+each+duafire&qid=1568168780&s=gateway&sr=8-1-spons&psc=1&qualifier=1568168780&id=1956358035558845&widgetName=sp_phone_search_atf
Note: Not the same seller but that model
Controller:
Xbox One S
Note: I didn't buy it
TV:
Some Sharp tv. 1080p 60hz (or it's 59)
Note: also didn't buy
Problem:
Okay, so this pc has 2 spots for headphones. For some odd reason no sound comes out the front or it doesn't fit (idr if it fits)
The other is in the back with the mic. So naturally i plugged it into a splitter and got sound but there was no bass and it had static.
Plugging it into the tv sounded better but still static. (pretty sure atleast this one had static other might not)
Temp Fix:
But when it's plugged into a wired controller. It works just as well as the phone.
Just recently I tried it on my mom's win 8 laptop and it worked normal there too.
So something is up with this pc.
I'm thinking of getting a long usb cord untill I can get it to work in the front.
Been using a controller lately and plan on moving to the steam controller. Problem is... It doesn't have a headphone jack.
Thanks for reading. I'll be happy to find the info you need. This is just annoying :/
