why does my microphone level keep adjusting itself?
jasonpf1123
124
hello there everyone. i have a big problem with my microphone level in windows 7 64 bit home premium. when i use google voice or skype to place calls my microphone level goes down automatically by itself.say i talk to my girlfriend on there i'll have the recording tab open and try to keep moving the slider up and it fights me to keep moving it back down. i thought it was skype so i unchecked the auto adjust mic, no good. i switched the communications tab to do nothing, no good. i went into the registry and switched the google talk plugin audio flag to 1, no good, i went into the google chat settings tab and switched it to my mic instead of default device. no good. roll back audio drivers and updating them no good. i've tried every thing on the internet that people have said to do and it keeps on dropping even when i'm trying to keep it up. i think its possessed. please help. i will add details if any one answers me. lets figure this out. it seems like theres alot of people out there in my boat, that haven't had any luck either. thank you so much
Okay, I had the same problem with Realtek audio drivers and fixed it this way.
I'm using Gigabyte GA-990FXA-UD3 with Zalman z3+ tower
Do this:
1. Reinstall audio drivers to full
2. Restart
3. go to realtek site
download mathcing audio driver
IMPORTANT: DOWNLOAD THE MATCHING AUDIO DRIVERS FOR WINDOWS U HAVE
the blue bolded drivers no. 1 for 32-bit and no. 2 for 64, it should fix the problem automatically.
http://www.realtek.com.tw/downloads/downloadsView.aspx?Langid=1&PNid=14&PFid=24&Level=4&Conn=3&DownTypeID=3&GetDown=false
4. furthermore, when u install, go in realtek manager and click on the Folder icon on top right and disable front jack panel detection
It should work ,let me know if it helped.
Kind Regards,
Bahalor
its seems on Auto Mode. if you adjust it from your own headset i mean (Smart headset supports mic level on it self) or from skype itself. or maybe the control panel. you can check if they on auto . and make them Manual.
