My pc only have a display port for its output so I buy an dp to hdmi it works fine perfectly but when I shutdown the pc and turn it back on it doesn't detect the display. Does anyone have any solution for this issue?
https://www.lazada.com.ph/products/...ter-cable-4k60hz-i1687262316-s7288650664.htmlWelcome to the forums, newcomer!
Got a link to the adapter you're working with? Make and model of your display? Are you working with an iGPU or a discrete GPU?
