Why does my PC drops its wireless network connection every..
HarrY
444
Archived from groups: alt.internet.wireless (More info?)
Hi All
My router is a 3Com 3crwe754g72-a (it includes a router, DHCP server,
ADSL modem and gateway) and I have a 3Com USB Adapter on my PC
(3crwe254g72)
When I am online the connection to the router is dropped every 30
minutes. It is pretty regular and always after 30 minutes.
The only way to recorrect is to reboot the PC or remove the 3Com
adapter from the device manager (thereby reinstalling the adapter)
I have noticed that the adapter does get a little hot. Is that normal?
Settings include
On the Router
WEP128 (I tried WPA and that had not effect on the drop outs)
DHCP server is enabled on the router
Lease time is half a day
On the PC
Network settings is using the XP wireless network setup
WEP 128
WEP Shared Key
I do not use the IEE authentication
PC runs XP Pro SP2
If anyone has any ideas of things I could try I would be most
grateful.
cheers
Harry
G
Guest
Guest
>(3crwe254g72)
Power (green) management on the PC. Your PC is going into power save
mode and turning off the USB adapter. It fails to appreciate your
ecological efforts and hangs. The same thing can happen if you enable
the power save mode on the wireless client. I don't have any
experience with the 3com products, but I do know of other drivers that
fail to recover from power save.
1. See if you bios supports power management and make sure the IRQ
line that runs the USB port is listed as "wake up" for power save
mode.
2. Just turn the power save junk off.
Jeff Liebermann jeffl@comix.santa-cruz.ca.us
150 Felker St #D http://www.LearnByDestroying.com
Santa Cruz CA 95060 AE6KS 831-336-2558
G
Guest
Guest
>mode.
Also, check the hardware/device manager power settings for the USB
devices. UNCHECK "Allow the computer to turn off this device to save
power" for all usb devices.
M
258
The 3COM USB adaptor isn't very reliable on my PC either. I find an easier
solution is to disable and then re-enable it in device manager. Now if
someone could write a macro to automate the process...
"Harry" <A@A.A> wrote in message
news:q7ppm0topuv7rueoq16or3fjegmaa3phnh@4ax.com...
> Hi All
> (3crwe254g72)
> Settings include
> On the Router
> On the PC
> WEP 128
> WEP Shared Key
> PC runs XP Pro SP2
> grateful.
> cheers
> Harry
G
Guest
Guest
>(3crwe254g72)
Go into the router config and check the idle time, follow the internet
settings wizard, it's on the page headed PPPoA. Set the idle time to 0
if it isn't already.
HarrY
444
On Wed, 13 Oct 2004 12:09:14 -0700, Jeff Liebermann
>>(3crwe254g72)
>mode.
I checked the BIOS and power saving and its all disabled.
Nope, this doesnt seem to solve it.
Thanks for the advice though.
Harry
HarrY
444
On Thu, 14 Oct 2004 16:41:24 +0100, Peter Johnson
>>(3crwe254g72)
I will try this tinight.
cheers
Harry
HarrY
444
>>mode.
I will look at this tonight
cheers
Harry
