Why does my PC have lag when on battery?
butti1430
Commendable
Sep 3, 2017
my pc is Lenovo legion Y520
16GB RAM
2 TB HDD + 128 GB SSD
you can have full details by searching name
please help!
when im on a charger it doesnt lag
when im on battery it does by -40 or -20
in COD BO 3 (i used a cracked one for performance test)
more than 60 fps for some reason(on charger)
less than 40(on battery)
Help!!!!!
I'll try, thank you!
Edit: it does but not at full performance though
thanks for helping!
Edit 2: It worked! full performance! Thanks!
Btw im new to this site its awesone
There may be other settings as well. That's why you don't game at Desktop performance on laptops. I am not sure, for example you could check your GPU settings, if you have your manufacturer (like Asus Aorus MSI) default app, see that it doesn't have any options to switch when on battery or check the voltage it gets.
