So, I've had the Asus ac750 for a while now, and often as I install something the card just disconnects from the internet and requires a reset, it doesn't even recognize any other connection until it's reset. I should note that because I've had it for a while it was in an entirely different motherboard as well with the same issue and that I've tried to reinstall drivers, update them, and look for older versions, disable sleep and hibernation mode as a suggested fix that worked for some people with the same results each time. Not sure if it's an issue with the card itself but it doesn't happen often enough to be completely unusable but often enough to be obnoxious.
My Components:
Motherboard: b450-f gaming
Graphics Card: rx580 xfx black edition
Cpu: Ryzen 5 3600
Memory: 2x8 g skill 3000mhz
Wifi card: Asus ac750
My Components:
Cpu: Ryzen 5 3600
