Why does task manager say that my memory is running at 800Mhz?
SeriousGaming101
330
Hello, I bought a couple of Corsair ValueSelect DDR3 8gb 1600 memory cards. All the sticks are the same model number: CMV8GX3M1A1600C11. However, one of them needs to enable XMP to get the full 1600mhz.(The rest are fine no XMP option.)
The problem is that my old AMD motherboard (880g chipset) doesn't allow me to enable XMP or change the ram frequency in the BIOS.
I went to CPUZ and it says that the memory that needs XMP enabled is running at 667Mhz and have a max bandwidth of PC3-10700 and the ones no XMP option is running at 800Mhz and have a max bandwidth of PC3-12800
Even without the XMP, the memory ram collectively should be running at the speed of the slowest slot which is at 1333mhz. However, my task manager says that it is only running at 800mhz at the memory section (On CPUZ it says its running at 399mhz on the DRAM frequency)
Why is my memory ram running at half speed? When I removed the XMP card and kept only the ones that does not require XMP. It says that the memory is running at 1333mhz by default. (This is fine for me.)
Without XMP, the card should be running at 1333mhz. But it seems like when I put all the cards together, its running at 800mhz(and not 1333mhz). Any ideas?
If it helps, my PC is a prebuilt DX4320-19 from Gateway but I have put a lot of upgrades to this PC into what some might consider a beast workstation.
Because of how RAM speeds are measured DDR (Double data rate) you have to double or quadruple the numbers some porgrams give depending on how they are calculating it.
In task manger 800mhz means the same thing at 1600mhz, 399mhz in CPU-Z means the same as 1600mhz. According to what you are telling me your RAM is running at 1600mhz.
This doesn't make snese to me. "I went to CPUZ and it says that the memory that needs XMP enabled is running at 667Mhz and have a max bandwidth of PC3-10700 and the ones no XMP option is running at 800Mhz and have a max bandwidth of PC3-12800"
This means your memory is running at 1600mhz. "Even without the XMP, the memory ram collectively should be running at the speed of the slowest slot which is at 1333mhz. However, my task manager says that it is only running at 800mhz at the memory section (On CPUZ it says its running at 399mhz on the DRAM frequency)"
I know what DDR (double date rate) is. However, I have seen some youtube videos that people with 2400mhz max speed says 2400mhz on their task manager. (Not 1200mhz).
If my ram was really running on max speed (1600mhz). Then shouldnt the task manager say that the speed is 1600mhz and not 800mhz.
Plus, I have seen my task manager say that my memory is running at 1333mhz, so there is no way my 1600mhz max memory cards is running at 2666mhz.
Well when I run that command I get 3200, I have two sticks of 3200mhz RAM running in dual channel mode. So you may be right, unless it is for some reason different with DDR4 or single chaneel mode if you are running your sticks in single channel mode.
I have no idea about the layout of a gateway BIOS, but you should be able to see what is set for memory speed in there somewhere and change it.
The size is not overstated, i have 3 sticks installed. (3x8). When I installed only 2 that doesnt require XMP, the speed is 1333. However, i never installed the XMP one by itself. Also, I dont think it matters what the speed is by itself because I have to install them together. I'm using slots 1 2,4. Its the only combination that they will work together.
