Why does the Seagate hard drive stop spin after power up?
robertruwan2
Hi,
My desktop internal hard drive stopped working suddenly on Windows 7. Then, it was not recognized by PC BIOS. The hard drive is:
Barracude 2TB
Its S/N: 5YD67T0P
ST2000DL003
P/N: 9VT166-302
F/W:CC3C
Date: 12135 Site: SU
Seagate refuses to repair it because it is an OEM drive, even though its website says the firmware has a bug.
I feel that it is the firmware problem as on the web:
http://www.ireckon.net/2009/05/unbricking-a-seagate-barracuda
When I do the repair as the above link, it does not have the exact phenomenon to me. That is, when I power the hard drive up, and connect the RS232 to my PC, the putty terminal window shows:
Boot 0x40M
Spin up
I do not see the above repair link said these info in the terminal window. Furthermore, I can clearly feel that the hard drive stops spin as there is no light vibration on the hard drive body.
BTW, I power the hard drive with a spare PC power supply. It is turned on by short the green and the nearby black pins. The power supply' fan turns. It obvious outputs power when the hard drive stops spinning.
I have post my question to the repair link, but there is no reply yet. Forgive me I post it here hoping to get help from some experts.
Thanks,
Hello,
I restore the hard drive PCB back and to get the echo message when it is powered up. Could you tell me what wrong with this drive?
Thanks,
Boot 0x40M
Spin Up[0x000246DF]
Trans.
Rst 0x40M
MC Internal LPC Process
Spin Up
RECOVERED Op=0900 Resp=0005
(P) SATA Reset
MediaPartition:
Host LBA Length Disc LBA Length Start Cyl Head
Media Partition 00000000 00999800 00000000 00133300 00000000 00000000
MC 00000000 00989960 00000000 0013132C 00000000 00000000
MSP 009912A0 00000C20 00132254 00000184 00000215 00000004
User Partition 00999800 00133300 00000220 00000004
MCMainPOR: Start:
Check MCMT Version: Current
MCMainPOR: Non-Init Case
MC Seg Disc and Cache Nodes: 40134924 40132A34
Seg Write Preamble VBM start: 000011B2 end: 000011D9
Footer - start: 000011DB end: 00001202
Seg Read Preamble VBM - start: 00001204 end: 0000122B
Footer - start: 0000122D end: 00001254
Reconstruction: MCMT Reconstruction Start
Max number of MC segments 22E0
Nonvolatile MCMT sequence number 01B06CCC
[RSRS] 0B4B DiscLba 00062D04 RW_RTL FFFFFFFF
Reconstruction: Completed 1:
[MCMTWS]
MCMainPOR: MCTBufferPtr->Header.MCStateFlagsDisc = 00000041
MCMainPOR: MCTBufferPtr->Header.MCTStateFlags = 0000002A
MCMainPOR: MCStateFlags = 00000041
MCMainPOR: Feature Enabled...
MSP MainPOR:
MSP Init Metadata
Buf Bytes/VBM 00000210 DBA Base 40000000
Metadata size in bytes 0040
Num Segments 0061
Logical Sector Alignment 00000000
MSP Reconstruction
MSP Read ScratchPad Section 0000 DiscLBA 00132254 BlkSize 00000C20 Num Segments 00000061 DiscLba 00132254 RW_RTL 000F4240
No valid segments found
MSP MSP Main Store Verify Reconstruction Status 10003000
Reconstruction Status 00003000
MSP Init ScratchPad on DiscDiscLBA 00132254 DiscSize 00000184 PhyBlkLBA 009912A0 BlkSize 00000C20
Write MSP Segment PhyBlkLBA 009912A0 BlkSize 00000C20 DiscLba 00132254 RW_RTL FFFFFFFF
MSP MainPOR: Complete
MSP MainPOR: Feature Enabled...
ScratchPad restore NOT required
(DOS)STE OGHT: 0x043A6704 - 0x043A84F4 - 0x00007FC8 - 0x00007FDC Count 0049
(DOS) Refresh Start.
(DOS) Read Error - .
