Why does turning an internal hard drive into external cause problem?
Vorpike
75
Why can't I simply take an internal hard drive, plug it into a SATA to USB and plug it into a USB port? The hard drive isn't readable and apparently the only way to make it so is by formatting it.
You can and that should be fine. First things coming to mind is the partition type. What computer is it coming from/OS and which computer do you use it on/OS?
Was this internal hard drive with an OS?
