I'm using a Phanteks 140mm static pressure fan in the side panel slot closer to the front of the case here:
The problem is, my GPU and CPU max and average temps are the same during stress tests, regardless of whether the side fan is running at min or max RPM.
Maybe it's mounted in a bad position? The fan isn't really blowing over the GPU, it's blowing right below it - but that's where the GPU intake fan (blower design) is drawing from, so I'd still expect GPU temps to be lower. Any ideas?
