I'm somewhat skeptic you'd see such surges if someone were to yank the power cable, even if with stabelizing circuitry and capacitors I could imagine some voltage lines might "surge during death throes".Sudden power loss can send shock (electrical surges) through a computer if not connected to a proper surge protector or battery backup. It is essentially like a component getting hit by static electricity just on a much larger scale.
There are two different problems, IMO.I am also wanting to know what issues sudden power loss can cause.
what were to happen if say, the power cord was suddenly yanked from the wall?Also you have to consider ESPECIALLY if the power failure is disaster or accident related, it's likely that the power doesn't drop straight out but flickers a few times and then stays out. That alone can do weird things to a computer if it's not set to stay off when the power fails.
The PC would shut down. If it doesn't happen repeatedly, probably nothing long term. It might trigger Startup Repair from Windows.what were to happen if say, the power cord was suddenly yanked from the wall?
so no permanent damage? I have pets and occasionally (once every few months or so) the power cord gets yanked by my dog tripping over the cord.The PC would shut down. If it doesn't happen repeatedly, probably nothing long term. It might trigger Startup Repair from Windows.
No, my cat LOVES to sleep next to my old tower and she occasionally pulls mine out.so no permanent damage? I have pets and occasionally (once every few months or so) the power cord gets yanked by my dog tripping over the cord.
I cannot imagine how much cat hair would accumulate in the fans of that system.No, my cat LOVES to sleep next to my old tower and she occasionally pulls mine out.
Real world experience:I cannot imagine the damage that a lightning strike would do to a plugged-in PC. Would it fry it or does it depend on other factors?
scary, was said amount of electricity in the air enough to be harmful?It was ON. Apparently, enough electricity through the air to turn it ON.
Well, I'm still vertical and breathing....apparently not...😉scary, was said amount of electricity in the air enough to be harmful?
My family (myself included) is horrible about this, we never disconnect anything during storms, even though we probably should. Also if a device has a 3rd prong on the plug into the wall, would that help prevent it from getting fried, or what is the third prong for?Well, I'm still vertical and breathing....apparently not...😉
And in my above situation, the wall plugs were not affected, on ANY device.There's other factors that have to be taken into play with a lightning strike. It's why its beneficial to at least have it on a surge protector.
I feel you.Well, I'm still vertical and breathing....apparently not...😉
How expensive is a UPS? Looking on PCpartpicker, there is a UPS listed for $19k, but I am not sure if they are supposed to be that expensive.The most damaging types of events related to power a computer can experience are brownouts, sudden loss of power while firmware, BIOS, or drivers are being updated, and sudden bursts of high current like from lightning. Lightning can cause all sorts of issues but it really depends on where it strikes.
If a strike affects ISP equipment then a burst of that electricity can go into your modem => WAP => PC. The way to protect against this kind of surge would be a surge protector with coaxial and ethernet ports that can filter out the surge before it hits the modem, or at least the PC depending on the surge protector. Of course having all your devices be wireless will at least protect them from being hardwired into the WAP or switch.
With brownouts you need a decent UPS unit to protect against them. Brownouts are potentially more damaging than surges for electronics. The same goes for sudden loss of power during delicate firmware, BIOS, and driver updates, you need a decent UPS.
I have these:How expensive is a UPS? Looking on PCpartpicker, there is a UPS listed for $19k, but I am not sure if they are supposed to be that expensive.
In the 100-400 dollar range is usually where most reasonable priced to their performance UPSs are at.How expensive is a UPS? Looking on PCpartpicker, there is a UPS listed for $19k, but I am not sure if they are supposed to be that expensive.
Im partial to Tripplites products. They have never failed me.
