Z Zhi_1_ Prominent Apr 2, 2017 4 0 510 Apr 2, 2017 #1 why im using NVIDIA GeForce 940M 4GB lag when i playing gta5
Saga Lout Retired Mod Mar 31, 2010 24,042 309 69,740 Apr 2, 2017 #2 Could you please supply some more information about your system to enable folks to help you? From your Windows Start button, right click on This PC (assuming Windows 10) and the CPU and Memory (RAM) details are in there. Upvote 0 Downvote
DSzymborski Curmudgeon Pursuivant Moderator Nov 19, 2010 21,209 5,330 106,640 Apr 2, 2017 #3 Well, what are your settings and the actual FPS? Useful answers don't typically result from vague questions. Upvote 0 Downvote
Z Zhi_1_ Prominent Apr 2, 2017 4 0 510 Apr 2, 2017 #4 acer E5-575G RAM:4GB PROCESSOR:INTEL(R)CORE(TM)I5-6200CPU@2.30GHz 2.40GHz Upvote 0 Downvote
J_E_D_70 Splendid Mar 21, 2012 7,291 59 30,290 Apr 2, 2017 #5 http://www.notebookcheck.net/NVIDIA-GeForce-940M.138027.0.html You need to be playing at low settings (see link) and low resolution (below 1080p) to get reasonable framerates. Your cpu is on the lower end and you have the bare minimum RAM required. If you're running anything else in the background it's just making it worse Upvote 0 Downvote
Z Zhi_1_ Prominent Apr 2, 2017 4 0 510 Apr 2, 2017 #6 but im playing with low graphic but still lagging Upvote 0 Downvote
DSzymborski Curmudgeon Pursuivant Moderator Nov 19, 2010 21,209 5,330 106,640 Apr 2, 2017 #7 Zhi_1_ : but im playing with low graphic but still lagging Again, what resolution are you playing at and what frames per second are you getting? Nobody can diagnose anything with just your subjective feel of lagging to go on. Upvote 0 Downvote
J_E_D_70 Splendid Mar 21, 2012 7,291 59 30,290 Apr 2, 2017 #8 Try setting nvidia control panel AND windows power to maximum (instead of balanced or whatever it's set at). Go into systray before starting game and close anything you dont have to have. Would get another 4gb of ram if you have a free slot. Upvote 0 Downvote
Z Zhi_1_ Prominent Apr 2, 2017 4 0 510 Apr 2, 2017 #9 the highest fps is 80 but whn i drive it will drop until 1 Upvote 0 Downvote
