Why is 8-pin EPS keyed differently from 4+4 pin?
ManOfArc
425
I noticed that the 4+4 pin is keyed differently than the 8-pin. Yet they both fit an 8-pin header. Why aren't they keyed the same?
Picture here
PS
How do I embed a picture directly into my post. Not a link.
Choose get share links for your upload and select the forum code which is BBcode:
Seriously? Shapes don't matter? Then why bother? Rounds will fit squares, but squares will not fit rounds.
I'm not disputing your answer, just surprised is all.
And thanks for the help with posting pics in the post. But what is the BBC code you refer to? You said "select the forum code which is BBcode:", but didn't finish.
