Why is alg.exe process running?
G
Guest
Guest
Archived from groups: microsoft.public.windowsxp.basics,microsoft.public.windowsxp.general,microsoft.public.windowsxp.perform_maintain (More info?)
Hello
I turned off Windows Firewall. I do not use Internet connection sharing. Why
OS is Windows XP Pro SP2.
Start | Run | Type: services.msc | OK |
Double click: Application Layer Gateway Service |
Set to: Disabled | Apply | Click the Stop button | OK |
Close Services
Hope this helps. Let us know.
Wes
In news:%23$u7kVYmEHA.2096@TK2MSFTNGP15.phx.gbl,
Dmitriy Kopnichev <kopn@hotbox.ruDELETE> hunted and pecked:
> Hello
> sharing. Why is alg.exe process running?
Archived from groups: microsoft.public.windowsxp.basics (More info?)
Thank you
"Blane" <a-blclar@online.microsoft.com> wrote in message
news:ti97ZdZmEHA.3024@cpmsftngxa10.phx.gbl...
> Dmitriy,
> Thank you for your post.
> There is always the potential that a malicious copy of the alg.exe has
> been
> installed by a spyware program. If the file is not in either
> c:\winnt\system32 or c:\windows\system32 then that copy is very suspect.
> Try renaming the file (if it is outside of c:\winnt\system32 or
> c:\windows\system32) and reboot. See if the process starts and you can
> still access the internet.
> I would recommend running a third party spyware tool to scan for spyware
> as
> well.
> Best regards,
> Blane Clark
> This posting is provided "AS IS" with no warranties, and confers no
> rights.
> You assume all risk for your use.
> (C) 2003 Microsoft Corporation. All rights reserved
Thanks
"Wesley Vogel" <123WVogel955@comcast.net> wrote in message
news:uKzpz0ZmEHA.3452@TK2MSFTNGP15.phx.gbl...
> Close Services
> Wes
>> Hello
Application Layer Gateway Service turned to Manual at Windows Firewall
turning off. I think alg.exe will not start anymore.
> Close Services
> Wes
>> Hello
