I have 3 front panel fans and one exhaust in the back. I even have my side panel off and cpu is running at 60 degrees celcius and im only running at 4 ghz . I cant overclock it to 5 because itll jump to 75-90 degrees celsius when i play apex or and i can smell it. Im using a cooler master maker 8 for cooling. I tried re-applying different thermal paste and didnt help. I want to at least game at 5 ghz. I admit the case i have is a vision II - BG and doesnt have the best airflow but with the side panel off i should def not be hitting up to 90 degrees. When i leave my clock at 4 ghz i hit an idle of 34-40 degrees which is kind of high since i have a pretty decent cooler.
Asus Z390 Plus gaming mobo
Asus XC Black Rtx 2070 gpu
i7 9700k
Cooler master master maker 8 cooling
Evga sc ddr4 series 16gb ram
Vision II -BG pc case
EVGA G3 750 watt Gold 80+ psu
Samsung evo 500 gb m.2 SSD
1tb seasonic HDD
Windows 10 home
i7 9700k
1tb seasonic HDD
Windows 10 home
