So, I got a Asus ROG 980 ti matrix (platinum) and one of my fans don't spin, it only spins when you gpu decides to max the fans, is there any reasons why?
I'd say that's normal. A lot of GPU's try to stay quiet while not under load. Unless the fan sticks when spun manually or temps are high, I'd say it's normal.
Yes, they idle at around 28 but it's one the 1 fan that turns off, shortly after that the fans go to 100% and then it starts spinning at repeats the process until under load.
