Question Why is my monitor not turning on? Am I not plugging things in the right place?
Jan 7, 2021
4
I’m new to computers and I found a PC that I had a couple years back but the monitor won’t turn on at all. Am I plugging things in wrong? Thanks in advance!
PC wires photo
Monitor wires photo
the DC IN on the monitor plugs into the wall and my PC has two VGA and HDMI cable and I’m not sure where to put the cables
Jan 7, 2021
4
You only need to use the hdmi cable......take out the vga cable
Although I still think the monitor should turn on.
Check the power plug at the wall and at the monitor.
I took out the vga cable and the power in the wall is working but it still won’t turn on. Is that something wrong with my monitor?
Jan 7, 2021
4
You don't need both plugged. It's one or the other. HDMI or VGA.
Do you have a graphics card in your system? If you do you need to plug the HDMI or VGA on the GPU and not on the board.
I’m not too sure but I believe it does have a GPU since it was built to be a “gaming” computer. Should I plug it into the other HDMI area?
Jan 7, 2021
4
Pop nvm it worked when I changed the HDMI to the GPU thanks so much!!
Look at the picture below. The top connection are for the motherboard / CPU integrated graphics. If you have a Graphics Card and you see an HDMI connection like the picture at the bottom then yes you have to connect to the GPU and not the motherboard.
https://support.cyberpowerpc.com/hc/article_attachments/360028079213/Display_Outputs.jpg
