Why Is my TJ max so low??
Infected925
Commendable
Dec 28, 2016
5
In RealTemp My TJ max is around 50-55 and when idle or when i play games im always around 40-45 Is MY cpu the problem or is my cpu cooler not good enough. by the way my cpu cooler is the Cooler master Hyper TX3 EVO
Then you have nothing to worry, The distance to TJ max is how many degrees in celcius it will have to be, added onto what your temp reading is currently, the lower this number gets the more dangerous it becomes. for instance, your TJmax is 100C, your CPU is...
correct me if im wrong, please provide a screenshot. Does it not say ""Distance" to TJmax" which sounds more likely given the numbers you have stated rounding to around 90c-100c the typical Thermal Junction Maximum
Yes it does say distance to TJ Max
Then you have nothing to worry, The distance to TJ max is how many degrees in celcius it will have to be, added onto what your temp reading is currently, the lower this number gets the more dangerous it becomes. for instance, your TJmax is 100C, your CPU is 40C so your distance to TJ max will be 60C.
