Archived from groups: comp.dcom.lans.ethernet (
More info?)
"J. Clarke" <jclarke@nospam.invalid> wrote in message
news:cilbr51302j@news4.newsguy.com...
> Al Dykes wrote:
> > In article <a92dnZIU2P_bmNPcRVn-pg@io.com>,
> > Daniel J McDonald <djmcdona@fnord.io.com> wrote:
> >>In article <%mH2d.394$Lq3.262@newsfe3-win.ntli.net>,
> >>stephen <stephen_hope.xx@ntlxworld.com> wrote:
> >>>"sharkie" <itsharkopath@yahoo.com> wrote in message
> >>>news:105ab9cd.0409170801.5201d392@posting.google.com...
> >>>> Hi,
> >>>> I am new to networks. I have read that Token rings are more
> >>>> expensive than ethernet. They seems to be using same amount of
> >>>> cabling, don't they ?,
> >>No, they used more expensive cabling - IBM Type-1 cabling is rather hard
> >>to work with, and the hermaphroditic connectors take a whole lot more
work
> >>to install than an RJ45.
> > When TR came out Ethernet was the original think orange coax with
> > vampire taps. The IBM design looked very good for wiring an office in
> > comparison.
> > The original 100 node/500 meter limit looked fine in 1980. In the
> > original design I don't think anyone gave any thought as to how to
> > link thinknet segments together to extend them. For a Data Center
> > with raised floors, ethernet was fine.
> > Token ring never got faster than 16Mb/sec as far as I know, and many
> > people though that 10Mb/sec ethernet was as fast or faster, most of
> > the time. As soon as 100Mb ethernet with managed hubs hit the street
> > TR was dead for new projects, except for diehard IBM shops.
> IBM was shipping 100 Mb/sec Token Ring ages ago. The trouble with it was
> that the switches cost vastly more than for Ethernet. And they still cost
> vastly more than for gigabit Ethernet, and no doubt if they're still
> available when 10 gig over copper goes mass-market they'll cost vastly
more
> than that as well. One thing IBM never got, even after the PC hit, was
the
> effect of competition on cost and performance--for Token Ring to continue
> to be a player it would have to go mass-market--there's no way that
anybody
> could continue to justify it over something that was both much cheaper and
> much faster.
IBM gave up on networking hardware (incl token ring switches, hubs and
routers) in a technology / patents for money deal a few years back
they formally announced that they would suggest anyone wanting these types
of hardware use Cisco...(i was working of an IBM network reseller at the
time, and this killed that part of our business - apart from 2nd hand gear
for companies who couldnt change quickly....).
Some bits and pieces probably survive - i havent checked for a while.
See www.networking.ibm.com
www.redbooks.ibm.com if you are interested.
> > The cost of the NIC is small potatos in the budget for a corporation
> > wiring a facility. Wiring costs are much higher, but even they get
> > amortized over years.
> The cost of an Ethernet NIC. The cost of a Token Ring NIC and switch port
> is considerably more than the cost of the drop in most cases.
> > Reliability and Time required to loacte and fix
> > a problem very important and corporations will pay for it. TR was
> > ahead of Ethernet in this regard until managed UTP/STP hubs were
> > developed.
> >>> is it expensive to build the NICs for Token
> >>>> ring ?,
> >>Yes. Each token ring nic needs its own microprocessor, where an
Ethernet
> >>nic has just a few fifos.
> >>>>is it management cost that is higher in the case of Token ring
> >>yes. Tracking down a problem in a token ring requires young guys with
> >>good ears to run over to a closet and find the connection that's
clicking.
> >>The experienced guys who spent too much time in raised floor rooms would
> >>lose their hearing from the incessant AC noise and not be able to hear
the
> >>tell-tale click of a machine beaconing.
MAUs got replaced with better electronic hub designs a long time ago - i
think Synoptics and Proteon were a couple of the early companies - and both
got eaten by others over a decade ago.
> > What did he say ???
> > IME The SNA guys could identify failing equipment without getting out
> > of the chair in the warm, quit, office.
> His experience with Token Ring is clearly more outdated than mine, and
> mine's pretty outdated.
> --John
> Reply to jclarke at ae tee tee global dot net
> (was jclarke at eye bee em dot net)
Regards
Stephen Hope - return address needs fewer xxs
