[SOLVED] Why low FPS even though I have a GTX 1050 Ti?
Aug 10, 2020
Hi guys! I have the nvidia gtx 1050 ti now then i play some games like dota,csgo and pubg but the fps is very low is like 30-50 fps in dota. How to boost fps for my games?
My specs:
CPU: AMD A8-7680
GPU: GTX 1050 TI
RAM: 8 GB
MOTHERBOARD: ASUS A68HM-K
MONITOR: HP V194
I feel as if that is pretty reasonable with a low end cpu and a low end gpu. I would play any of those games pretty much at lower settings and try to lower the resolution as well.
Make sure your monitor is actually plugged into the 1050Ti. If you have the monitor connected to the motherboard, then you are using integrated graphics which will be considerably slower.
In the case of PUBG you are probably also going to have your performance limited by your CPU. The A8 7680 is a very weak CPU and PUBG tends to require a fair bit of processing power to handle the large playercount in its games.
