So I'm looking at these USB addons that fit into a 3.5" floppy bay and bring USB 2.0 ports onto the PC case front panel, and I can't figure out why they put a molex connector on there. Each PC case essentially has / had front panel USB 2.0 ports built-in, and it only features a cable that you then plug onto the motherboard 9 -pin USB connector and you got USB 2.0 on the front. There is no extra power required. The front USB ports are usually soldered onto a small PCB along with one or two added capacitors (I'm guessing those are required due to the cable length), but that's it. USB 3 addons seem to be straight-through, but USB 2.0 ones seem to use the PCB with added capacitors and that molex connector, apparently for some kind of power. But why?
Example:
Example:
![3-5-inch-9Pin-to-2-USB-2-0-Port-HUB-Splitter-Floppy-Bay-HD-Audio.jpg_.webp](/proxy.php?image=https%3A%2F%2Fae01.alicdn.com%2Fkf%2FH9d9f031bde92435b8c7b5122426da347r%2F3-5-inch-9Pin-to-2-USB-2-0-Port-HUB-Splitter-Floppy-Bay-HD-Audio.jpg_.webp&hash=7e619f4a42884d2444bb47058a4381a6)
![71sp0ZEhBWL._AC_SL1500_.jpg](/proxy.php?image=https%3A%2F%2Fm.media-amazon.com%2Fimages%2FI%2F71sp0ZEhBWL._AC_SL1500_.jpg&hash=1f68cc4856f75109757ffc8224cf96a1)
