Why printer installed as 740 ESC/P and not USB in XP
marie
36
Archived from groups: comp.periphs.printers (More info?)
When using my Epson 740 printer on Win98 it installed as Epson 740 USB
and worked fine. Now using WinXP is installs as a 740 ESC/P and
operates anything but fine.
What does ESC/P indicate? How can I install it to the USB port as it
is supposed to be.
Thanks in advance,
Marie
[This followup was posted to comp.periphs.printers and a copy was sent to
the cited author.]
In article <9pp3b0dtr2kiuqqbsrmaq78363vmgfgkn0@4ax.com>, dokee@tpg.com.au
says...
> is supposed to be.
ESC/P is the printer language. Under Win98, you probably had Epson-
specific drivers. Under XP, you are probably using the built-in drivers.
Just what is not working properly?
A quick check of Epson's web site doesn't show XP specific drivers,
although there are Win2K drivers that MIGHT work. You can also download
the status monitor if you like that kind of stuff running in the
background. (Long link below, cut & paste back together)
http://www.epson.com/cgi-bin/Store/support/supDetail.jsp?
BV_UseBVCookie=yes&oid=14422&prodoid=10614
&infoType=Downloads&platform=Windows
If there is a no_junk in my address, please REMOVE it before replying!
All junk mail senders will be prosecuted to the fullest extent of the
law!!
http://home.att.net/~andyross
"Marie" <dokee@tpg.com.au> wrote in message
news:9pp3b0dtr2kiuqqbsrmaq78363vmgfgkn0@4ax.com...
> is supposed to be.
> Thanks in advance,
> Marie
You have to install Epson's USB driver from the CD. Not an easy task as I
remember, quite convoluted.
Eddie
