Hello,
Today I had a weird problem with my Gaming PC. I move it around a lot and moved it upstairs since someone was my room was unavailable at the moment. I was moving it around back and forth on the dining room table to get the best set-up position and I wish I had just left it alone but once or twice I switched off the power supply manually like I always do. However the second time around or third time it wouldn't turn on. Previously a few weeks or couple months ago my PC crashed on start up or would just crash all-together. I am worried that it was my hard drive because when I opened up the case my hard drive was loose.
The screw had popped off because I modded the ODD bay to fit my hard drive since it wouldn't fit in any of the hard drive cages initially in the case. My PC had been fine before and worked like charm but now it won't turn on. Just to see what was wrong I reinstalled the screw and tried again. I tried with multiple extension cables so I know that's not a problem. I could try new power cables. My monitor works and turns on so I know that's okay. It is either my power supply or hard drive because when I unplugged my hard drive and turned on my PC without the HDD I turned on my PC and the Corsair H60 and case fans turned on for a few seconds and then died. So it is a power supply failure?
I am thinking it is either a PSU failure or an HDD failure or both. My PC is over a year old and I only have an EVGA 500 watt PSU. It worked fine with my system until I replaced the cooler master 212 Hyper evo with the Corsair H60. My specs: i5 4690k, lga 1150 motherboard (micro atx), 1.5tb hdd, zotac gtx 970, and 8gb of ram with the Fractal Design Core 2300. What is wrong with my PC? Is it a mobo failure? Dead PSU or dead HDD?
Many thanks in advance!
