[SOLVED] Why won't my GPU send out a signal to my monitor
jjnorris123
When I shut down my system last night, everything was working perfectly. When I have booted up this evening the monitor is showing a no signal message when the HDMI is plugged into the graphics card. The rest of the system is ok because there is a display when the HDMI is plugged into the motherboard and uses the onboard graphics.
Is there any explanation as to why this has happened?
Cheers
What card is it?
Usually a bad card will prevent a boot so it could be a PSU issue, as in the card isn't getting enough power. Check to see if the cables are still connected properly.
The only other thing I can suggest is if you can borrow a friends card or test your card in another system.
What card is it?
