why wont my razer carcharias headset work i have audio but the mic doesnt work
Marko200
8
Hey there can someone please help my with this problem so i nough my razer carcharias few months ago and i was using them on xbox 360 and everything was perfect but then i switched to pc and when i plug them in and everything i have sound but my mic is not working.Thanks in advance
Depends on where you are plugging them into your Pc.
If you are using the two front 1.5mm audio inputs on a pc tower or case.
In windows sound manager it treats the inputs and output devices differently.
For example if you look in windows sound manager you should see two mics. when clicking on the record devices tab.
If it shows two in there, simply right click on one and set it as the default recording device.
Its likely the mic is set to the rear port or 1.5mm jack of the mobo, or vice versa at the front but you still have to switch the default playback and recording devices and set them in windows sound manager.
After that it should work.
I know it works because years ago I worked this out in the end.
Make sure the mic is not...
Make sure the mic is not muted on the volume control of the Razer headset also, should be a mute switch on the top or side.
Make sure you are plugging both jacks. The pink one should go into the pink jack of your pc. Also make sure your mic is switched on from the small volume rocker that you have along the wire. Also go into sound settings , recording and set the mic as default device.
