Question Wich Monitor is best for my needs?
Mar 5, 2019
I'm in search the best monitor for my budget and i'm not so fluent in Display knowledge, so i'm here to find help.
I'm from Italy. I am a 3D artist mainly for videogames, and i plan to use my monitor for gaming (not competitively, mostly single player offline games) AND work.
I need the color to be quite accurate (for texturing primaraly). I plan to use it as a Primary Display for my laptop with an hdmi cable. I Have an Alienware with a geforce GTX 1060 driver version 418.81. I am fine with full HD 1920x1080, and 75hz (tough 60 hz is fine also i think). 24'' is enough, 27'' is appreciated, on a 16:9 ratio, no ultra wide or anything.
My budget is not much, 250-300 euros top.
I'm not in searching for a brand in particular, i'm fine with all.
i have recently tried an AOC G2460VQ6 but the color was not great, though with enough calibration i had reach a decent look, but playing with the shadow control setting fucks up most games, with the result of seeing absolutely nothing in dark areas. (and in some old games i can't adjust the brightness).
What Monitor is the best for me?
As long as you choose an IPS or VA monitor, you will be happier with the colour
As for make/model -there are many to choose from, but you do NOT want a TN screen which is the one you tested.
Just choose a brand you trust and look online for it, there are so many reviews about monitors.
