hello all, i need some BIG help as i have a really weird ( and majorly frusterating)CPU cooling issue. i have just built a new gaming PC hat i do not intend to overclock. i have an antec duel raditator watercooler, decent z270 mobo, and a i7770k ( i went with this over the 7700 due to the higher clock speeds) now i built together nicely with decent silver based thermal paste. booted first go and everything, but i noticed that the temps in bios for CPU were around 45, which is way too hot for my liking under stock clock and watercooling. i loaded windows onto it, updated everything, installed all mobo chipset drivers, flashed bios to newest version. now not only is the temps bad in bios, on idle using many different third party programs ( aida64, HW moniter ect) my idle temps are about 34 ish, thats not the werid part, weird part is they fluctuate like crazy, like they randomly jump say 30 degrees at a time instantly, under seemingly no load, and when under load uaually jump to about 55 - 60 degrees, then back down, this is all cores and happens under random loads. the jumps apear random, and are extremly inconsistent. they flutiate wildly. however the system is very stable, i ran a stress test from 2 differnt programs, stressing the cpue for 3 hours each and never jumped past 70 degrees. i reseated and double checked the heatsink is seated properly and used the correct amount of thermal paste, also used pea method aswell correclty. done that 4 times now.... i cannot for the life of me find the cause of this strange heating issue. any and all help is greatly apprteciated as i bellieve a componant may be faulty, but due to purchasing [parts online seperatly i need to figuer out what part to return. also the randomenss of the cores is independant to eachother, so one core may be up to 35 degrees diffence than others at any point, however under no load they seem to be not as jumpy but still have random swings. thankyou in advance
