Hi.
A few minutes ago, I started up my computer, and saw the "low disk space" message in the bottom right corner. I found this odd because I had JUST reformatted the previous week, and since then used up only a few gigs of space. I have 2 partitions. (C) and (D). I went into "My computer" and saw that my (C) drive only has 40mb of free space. (The C: partition has a total size of 97gigs.) The (D) partition is perfectly fine.
I am going to scan my computer for spyware/viruses, but I doubt that will help.
Does anyone know what could be causing this?
Btw, the (C) partition contains my windows installation, if that matters.
My systems specs:
Pentium D at 3.2ghz
1 gb ram
Maxtor Hard Drive. (It says Maxtor 6V300F0 in the device manager if that means anything to you.)
Windows XP Home.
My systems specs:
Pentium D at 3.2ghz
1 gb ram
Windows XP Home.
